Date/Time: Fri, 10 Jan 2025 23:01:53 +0000
market historical depth
View Count: 917
[2016-10-07 18:49:28] |
User579208 - Posts: 22 |
hello wich package do i need to get the historical depth to work ? im on package 5 thanks |
[2016-10-07 18:55:30] |
This requires Sierra Chart service package 5 which you are currently using. Here is the documentation: https://www.sierrachart.com/index.php?page=doc/MarketDepthHistoricalGraph.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-10-07 19:07:05] |
thanks for quick reply i set that up like instructions said but i get this says not supported by package could u check whats wrong regards |
Screenshot_2.png / V - Attached On 2016-10-07 19:06:50 UTC - Size: 51.99 KB - 276 views |
[2016-10-07 19:07:32] |
screenshot with log attached
[2016-10-07 19:16:26] |
This is now resolved. Restart Sierra Chart.
[2016-10-07 19:18:26] |
thanks
[2016-10-16 14:40:07] |
ephi144 - Posts: 54 |
@SeC Engineering team: would you please help me do the same. i just got started with SC. i have paid for it as well (Service package 5). |
[2016-10-16 20:31:21] |
If you want to see historical market depth data on a chart, then refer to this page: https://www.sierrachart.com/index.php?page=doc/MarketDepthHistoricalGraph.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
