Date/Time: Fri, 10 Jan 2025 21:44:40 +0000
Scale Settings seem 'locked up'
View Count: 783
[2016-10-07 08:40:41]
User78926 - Posts: 69
Hi there, can you please have a look at this image attached. There is nothing I can do to set the Scale Settings to correctly relate to the market - it seems as though they are locked up somehow.
Can you please help, if you need any other info please let me know.
Rgds, Mark
imageChart_Overlays_with_mixed_Scale_Settings.png / V - Attached On 2016-10-07 08:37:45 UTC - Size: 248.84 KB - 245 views
[2016-10-07 09:05:17]
This is very confusing. We cannot make sense of that.
Specifically tell us what particular setting you are trying to change and what is happening.
[2016-10-10 12:37:40]
Hi there, all I am trying to do get the scale settings that are relevant to each market and nothing responds as per the image I sent through. It's like it is frozen.
Rgds, Mark
[2016-10-10 16:49:21]
So you cannot set the Scale Range or other settings in the Scale Settings window?:
Chart Scale and Scale Adjusting
This makes no sense. There should never be a problem with that.
