Date/Time: Thu, 16 Jan 2025 07:44:11 +0000
Camarilla Pivot Points
View Count: 2313
[2016-10-07 02:56:23] |
User63769 - Posts: 35 |
Hello, My Camarilla Pivot Points display and work perfectly on all bar periods above one minute, but they don't display on bar periods of one minute or less. They display on 2 minute, 5 minute, 15 minute, etc, but not on one minute bar periods or less. This is not because they are outside of the chart region - they simply do not display. I have been working around this by looking at the values on a different bar period and then drawing rays to represent the pivot points on the one minute period, but I would obviously prefer to not have to do this each day. Any suggestions would be appreciated. |
[2016-10-07 04:29:31] |
Provide a Chartbook containing a single chart which contains the study so we can have a look at it. Here are instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-10-07 05:18:16] |
At the start of the new day, the Pivot Points for the 1 minute bars re-appeared. It is a bit of a mystery why the 2 minute bars showed the Pivot Points and not the 1 minute bars, but I now have no complaints.
[2017-10-24 17:42:06] |
Do you have any question here?
[2017-10-24 20:08:10] |
Sorry, I was sending a solution for the Camarilla Pivot Points problem to myself!
