Date/Time: Fri, 10 Jan 2025 20:04:28 +0000
Detached Chart - Regaining Menu
View Count: 738
[2016-10-05 17:09:58] |
User83524 - Posts: 33 |
I have a detached chart and removed the show menu. I have looked everywhere but can't find a way to get the menu to show again on the detached chart. I can access the chart settings but there is nothing to restore the menu. How do I regain the menu? Thanks!
[2016-10-05 17:34:37] |
Never mind.. I found it by right clicking near top of chart to restore menu.
[2016-10-05 17:56:00] |
Here is the relevant documentation: http://www.sierrachart.com/index.php?page=doc/ChartMenu.html#ShowMenu Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
