Date/Time: Fri, 10 Jan 2025 19:51:02 +0000
Number bar column spacing
View Count: 1079
[2016-10-05 15:12:58] |
canyiah - Posts: 48 |
I have 3 questions 1) Is there a way to set the Number bar columns to a default width? 2) Is it possible to pan vertically 3) is it possible to set spacing between the edges of the chart attached is a view of my chart where I cant see whats going on at the bottom of the chart also this happens when price gets to the top where I want to manually move my stop or target and cant get to it because I cant move vertical. ****updated**** I found how to pan vertically search for : Interactive Scaling, right click the price are select Interactive Scaling now on the price column you can move up or down dynamically Date Time Of Last Edit: 2016-10-05 15:16:41
not viewable.png / V - Attached On 2016-10-05 15:02:23 UTC - Size: 150.67 KB - 315 views |
[2016-10-05 15:30:31] |
Sierra Chart - Max - Posts: 5778 |
1. To change the Bar Spacing refer to the documentation here: Working With Charts: Changing Bar Spacing The default Bar Spacing is set on Graphics Settings: Graphics Settings: Default Chart Bar Spacing (Global Settings >> Graphics Settings >> Other) 2 and 3. Yes, refer to the Interactive Scaling documentation here: Chart Scale and Scale Adjusting: Interactive Scaling Sierra Chart Support |
