Date/Time: Fri, 10 Jan 2025 19:57:34 +0000
RC orderflow chart settings
View Count: 1292
[2016-10-05 14:22:39]
bbrunner - Posts: 14
Hello there,
I realized when I try to open the RC orderflow chart for HSI in two different computers that I use have different arrows and the numbers bars data are different. I believe the Orderflow chart from Office is the correct version. I want to know how can I reset the orderflow chart at my home computer.
I did try to delete the hsi orderflow.cht file in c:\sierrachart\data and reopen the chart and change back the symbol as I am using IB to connect but still cannot get it right. Since the orderflow chart is correct in Office computer I dare not to change anything.
Many thanks
Shelton
Private File
Private File
[2016-10-05 17:53:46]
There are two things you need to do.
You need to activate the Hong Kong futures exchange here:
https://www.sierrachart.com/usercp.php?page=ExchangeDataFeedFeatures
This is essential.
And follow through the instructions here to set Sierra Chart for a tick by tick data configuration:
http://www.sierrachart.com/index.php?page=doc/TickbyTickDataConfiguration.php
Once these are done re-download the data in the chart with Edit >> Delete All Data and Download.
