Date/Time: Fri, 10 Jan 2025 20:06:52 +0000
Orders to IB out of RTH
View Count: 1510
[2016-10-05 12:23:41] |
User805092 - Posts: 17 |
Hallo, I need to help with sending orders to Interactive Brokers outside of regular trading hour. I would like to make some trades before open on US markets, but if I click to chart DOM, orders are send to IB but canceled at the same time. Could you please help me with this? Regards, Jiri |
[2016-10-05 17:33:52] |
Select Global Settings >> Data/Trade Service Settings. In the list of settings on the left enable this option: " Allow Orders to Fill outside Regular Trading Hours". Or update to the current version of Sierra Chart by following the instructions here: http://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-10-05 17:34:30
[2016-10-05 17:38:43] |
Allow Orders to Fill outside Regular Trading Hours - True And I also have the last version of SC. So pls what else? |
[2016-10-05 17:58:11] |
In this particular case you need to contact Interactive Brokers and find out why the order is getting canceled. We do not know.
[2016-10-05 17:59:13] |
Thank you, I'll try.
