Date/Time: Fri, 10 Jan 2025 20:12:05 +0000
Chnages to Flatten & Cancel
View Count: 734
[2016-10-05 00:19:08] |
User553714 - Posts: 184 |
Hi, I have been having issues with my system for trading this morning with interaction of cells J28, J29, J78; my usual settings are resulting in a different behaviour resulting in a circular message loop to the Trade Service Log; have any changes with the way cells J27, J28, J29 & J78 interact been made, I only started having this issue after upgrading to version 1468 last night.. see video of behaviour |
Private File |
[2016-10-05 01:26:52] |
Hi, I have made another video to better illustrate the issue; whenever I set disable auto trading to true (I.E. CELL J28 = 1) I can't turn off the circular looping regardless of how I set cells J27, J29, J78... Your quick assistance to stop this issue will be appreciated.. thanks. |
Private File |
[2016-10-05 02:35:27] |
Surprised no one mentioned this earlier. We do see the problem and it is fixed. It was just a logging issue. However, there was a recent change, that when auto trading is disabled through the Disable Auto Trading cell and there is also a Flatten or Cancel operation that occurs at the same time, those will still take effect. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-10-05 02:36:00
[2016-10-05 03:12:11] |
Hi, Until you release the next SC version with these changes (probably a pre-release or will you wait to include in next release?); My most recent SC backup is 2-days old, what files do I need to copy across to revert back to the old SC version? I have made changes to other files (twconfig, spreadsheets, chartbooks & data) so I don't want to copy the entire folder. I am not sure I would notice any affect at all under the change that you described to Flatten/Cancel; presumably this change is to make sure flatten/cancel takes affect before auto-trading is internally disabled. |
[2016-10-05 08:41:42] |
We are going to have a new release out in about an hour. We recommend waiting. For the record here are the instructions to go back to an earlier release: https://www.sierrachart.com/index.php?page=doc/download.php#Rollback Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
