Date/Time: Fri, 10 Jan 2025 19:56:43 +0000
Renko Enhanced study -question
View Count: 733
[2016-10-04 16:34:34] |
User363944 - Posts: 2 |
i'm trying to use the Renko Enhanced study on daily data with intraday updating, but it doesn't update unless i go into chart setting and hit 'ok' to manually update. I do have the auto update option selected. Is this just an issue with the study itself? note: I do use the Renko Enhanced study on intraday data and it updates fine. thanks |
[2016-10-04 17:22:20] |
You instead need to use the Renko Bar Period Type setting in Chart Settings: http://www.sierrachart.com/index.php?page=doc/RenkoCharts.html It makes no sense to use the Renko Enhanced study on Daily data. It is not going to work properly. Besides that study is unsupported by us. It is only there for back compatibility but we provide no support for it. It has been discontinued for years. We also do not know what you mean by "auto update option". There is no option with this name. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-10-04 17:22:46
