Date/Time: Fri, 10 Jan 2025 20:17:04 +0000
TD Ameritrade
View Count: 2037
[2016-10-04 14:54:39] |
User82486 - Posts: 43 |
In attempting a BUY trade on the Sierra Chart DOM data connected to TD AMERITRADE the buy order is executed but the trailing stop and target a lost. When questioned TD tells me that Sierra did not transmit the ATTACHED oco AND THEREFORE CANNOT EXECUTE WHEN THE CONDITIONS ARE MET? What good is the data flow in placing orders if they are not completely placed. Obviously I can still use the charts but not the trading PLATFORM. I TRADE FUTURES WITH amp AND HAVE NO SUCH PROBLEMS. trades AND ATTACHED oco ORDERS ARE RECIEVED AND ACTIVATED WHEN HIT. wHAT SHOULD I DO ABOUT THIS? Fred |
[2016-10-04 16:58:22] |
We need to see the Trade Activity Log lines for these orders. Follow the instructions here: http://www.sierrachart.com/index.php?page=doc/TradeActivityLog.php#TradeActivityLogToSupport Also make sure you disable Use Server Side OCO and Bracket Orders: http://www.sierrachart.com/index.php?page=doc/GlobalTradeSettings.html#UseServerSideOCO Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-10-05 02:43:47] |
This is the problem: Order 2016-09-29 13:38:38.360 AMD Order Error - TDA order update. Conditional Orders are not permitted for accounts in this segment 8557 Limit 1000 Sell 7.00 Error * Close 8556 2000
Order 2016-09-29 13:38:38.361 AMD Order Error - TDA order update. Conditional Orders are not permitted for accounts in this segment 8558 Trailing Stop 1000 Sell 6.54 Error * Close 8556 2000 To solve the problem disable Use Server Side OCO and Bracket Orders: http://www.sierrachart.com/index.php?page=doc/GlobalTradeSettings.html#UseServerSideOCO However, you must keep Sierra Chart connected to TD Ameritrade at all times until the Target or Stop fills or is canceled. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-10-05 02:44:19
