Date/Time: Fri, 10 Jan 2025 20:26:50 +0000
Order disappeared
View Count: 806
[2016-10-04 14:48:49]
User638756 - Posts: 52
Im using the DOM and I have IB. I put in an order and it recieved it ok and even called out that it went thru, Then you look at the DOM and it says flat, even tho the order is still there. I use the sierra SIM and this doesnt happen.
[2016-10-04 17:01:08]
This is a very common problem with Interactive Brokers. Refer to:
http://www.sierrachart.com/index.php?page=doc/InteractiveBrokers.php#TradePositionLineQuantityDisappearingDisplayingZero
