Date/Time: Fri, 10 Jan 2025 20:17:01 +0000
sc.IsTradeSimulationModeOn?
View Count: 837
[2016-10-04 07:09:37] |
Pinger - Posts: 33 |
Hi Is there a "sc.IsTradeSimulationModeOn" variable similar to "sc.IsAutoTradingEnabled"? The reason I ask is that I would like to be able to do a "if (sc.IsTradeSimualtionModeOn == No && sc.SendOrdersToTradeService == Yes)" test in a study to determine whether I'm sending orders to my trade service or the simulation mode. These variables need to be set consistently so it would be nice to be able to test them together. Apologies for the question if the variable exists but I can't find it in the documentation. Kind regards |
[2016-10-04 07:11:57] |
It is: sc.GlobalTradeSimulationIsOn Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-10-04 07:20:05] |
Many thanks for the swift response. Cheers |
