Date/Time: Fri, 10 Jan 2025 19:54:30 +0000
chart dom and depth history
View Count: 1458
[2016-10-04 06:49:48]
User597594 - Posts: 17
my chart dom is not showing depth levels and the update of the market depth histroical graph is very slow - i am watching against my tt and it is many seconds behind. How can I fix these issues?
imageCapture.PNG / V - Attached On 2016-10-04 06:48:17 UTC - Size: 83.97 KB - 354 views
[2016-10-04 09:18:01]
can you please also tell me how i can have a horizontal line at price where the fill space starts thanks
[2016-10-04 17:11:24]
Follow the instructions here to configure the chart DOM columns:
http://www.sierrachart.com/index.php?page=doc/ChartTrading.html#CustomizeChartDOMColumns
This could be a data feed issue which we have no control over.
Or it could be a time stamping problem. Make sure your computer's clock is correct:
http://www.sierrachart.com/index.php?page=doc/helpdetails38.html
Also consider using the Sierra Chart Exchange Data Feed instead:
http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php
Use this study:
http://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s123
Date Time Of Last Edit: 2016-10-04 17:11:58
[2016-10-04 17:58:55]
and a vertical line sorry thanks
[2016-10-04 18:19:01]
We do not understand post #4.
[2016-10-04 18:21:28]
http://www.traderunner.pro/wp-content/uploads/2015/11/BookMap-Review-Real-Volume.jpg like the vertical line splitting the old depth from current depth
