Date/Time: Fri, 10 Jan 2025 20:24:14 +0000
Difficulty with reload and recalculate function in newer versions
View Count: 685
[2016-10-03 22:56:47]
User92081 - Posts: 4
I have been using the Reload and Recalculate command along with a Days to Load setting of 1 so that my charts only show the current session. I recently tried some newer versions of Sierra Chart, and my charts displayed multiple sessions. I could not get them to display only the current session the way they did under the old version. All the affected charts use volume bars. I reinstalled an older version of Sierra Chart to get the old functionality back, but I wonder if there's another way to do this in the newer versions. I'm using Sierra Chart 1392 now. The ones I tried recently that did not work the way I'm used to were 1460 and later.
[2016-10-04 00:54:26]
At most you would see two trading days in the chart and not more.
There was a small change related to this, and it would take some time for us to examine that again. But there was a good reason why we did make a change and it is not something we want to change.
During the day session, certainly if you were to load one day of data, then you are only going to see 1 day in the chart. But when the evening session begins we do see that the prior trading session is also loaded in.
