Date/Time: Fri, 10 Jan 2025 20:09:54 +0000
ACSIL question
View Count: 740
[2016-10-03 17:30:23]
Samir - Posts: 4
I need to get highest/lowest value over n bars, any function to do that?
[2016-10-03 18:47:18]
Refer to:
sc.Highest()
sc.Lowest()
[2016-10-04 07:17:38]
Pinger - Posts: 33
Hi
Try sc.Lowest and sc.Highest. The 'n' count includes the current bar. Be careful with the 4 parameter version as it starts 'Index' bars back from the current bar and then calculates the Lowest/Highest 'n' bars backwards from this point. I found this bit a little confusing to start with.
Kind regards
