Date/Time: Fri, 10 Jan 2025 20:28:50 +0000
Horizontal Lines Study Subgraph settings
View Count: 2252
[2016-10-03 16:54:54]
tradernikki - Posts: 41
I would like to create some sort of zones using the lines
I've used the extending rectangle before, which is great, but hard to manage as more zones are added
I'm using the draw style of Fill Bottom and Fill Top to create the same effect as the extending rectangle, but I'm missing some features:
- The transparency of the zones. Can this be added on the Lines study?
- Zones being extended to the right side of the chart to fill the empty space
- Would be great if the draw style "Line at last bar to edge" could be combined with the "Fill Top" and "Fill Bottom" mode, so we can color a zone only on the right side margin.
Thank you
[2016-10-03 18:33:30]
The only thing we can say is that there are transparent study Draw Styles. Refer to: Chart Studies: Subgraphs Tab >> Draw Style
The other items are not supported and there are no plans for these. And we cannot accept any new development at this time.
However, you could accomplish these other items through modification of the study:
https://www.sierrachart.com/index.php?page=doc/BuildCustomStudiesDLL.html
Although we do not provide programming help.
[2016-10-04 03:02:05]
If so, is it possible for the objects in "Manage Chart Drawings" to be sortable by price? So that it would be easier on the eyes when editing.
All right, I guess I need to learn ACSIL. As I have no programming background, should I learn ACSIL directly or better to learn C++ first?
[2016-10-04 03:19:43]
Yes.
