Date/Time: Fri, 10 Jan 2025 20:01:41 +0000
Change color of active Qty button in trade window
View Count: 1190
[2016-10-03 16:22:01] |
JohnR - User831573 - Posts: 307 |
Is there a way to change the active qty button in the trade window? At one point I changed the background to a dark grey, and that made it impossible to know which button was presses.
Trade Button color 2016-10-03_12-06-47.jpg / V - Attached On 2016-10-03 16:21:25 UTC - Size: 40.22 KB - 293 views |
[2016-10-03 18:29:19] |
No. This is not supported. You can change the color of all of the buttons. Refer to: Basic Trading and the Trade Window: Setting the Colors of the Trade Window Buttons Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
