Date/Time: Fri, 10 Jan 2025 19:53:01 +0000
Gain/OEC Orders entered in OEC platform not showing in Sierra Chart
View Count: 746
[2016-10-03 15:44:50] |
TIM - Posts: 16 |
Hello, I have a problem today with orders. The orders I ve entered in OEC execution platform don t show up at all in Sierra in charts, they do however show in Orders and Positions. I ve noticed Orders and Positions uses the Z6 code, while charts use the Z16 code. I use Sierra to manage the positions and orders in the chart. Not today. I hope it helps your team. My best regards, Tim |
[2016-10-03 16:51:09] |
We are thinking about a solution to this.
[2016-10-03 18:08:31] |
Refer to this posting here: Notice: Conversion to Two Digit Years for Gain Capital/OEC Trading Service Users | Post: 100471 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-10-03 18:35:11] |
TIM - Posts: 16 |
Thank you very much. My best regards, Tim |
