Date/Time: Tue, 06 Oct 2026 05:24:16 +0000
MACD Data Pull
View Count: 2111
| [2013-07-25 20:30:47] |
| User75554 - Posts: 5 |
"I am trying to get real-time MACD, MA of MACD, and MACD Diff data feed for a MATLAB/C++ program that I will use to assist me in trading. So far, I have only been able to export Intraday Quotes in .txt. Please let me know the most efficient way to obtain the MACD, MA of MACD, and MACD Diff data points from Sierra Charts. (Note that I'm trying to get the data to show up in some sort of spread, not a chart). Thanks." kayvontabrizi@gmail.com
Date Time Of Last Edit: 2013-07-25 20:31:17
| [2013-07-27 01:54:09] |
One way to do this is to save the data from a Spreadsheet study into a text file. Refer to the documentation here for Spreadsheet studies: http://www.sierrachart.com/index.php?l=doc/doc_StudiesSystemsAlerts.php Another way is to write your own custom ACSIL function to write the data to a text file. Refer to: https://www.sierrachart.com/index.php?l=doc/doc_CreatingDLLs.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
