Date/Time: Fri, 10 Jan 2025 20:23:44 +0000
Volume by price, volume bar tick count issue
View Count: 780
[2016-10-03 14:51:16] |
User91630 - Posts: 25 |
After updating Sierra Chart this morning(I have OEC datafeed), all of the charts within my chart books were converted to daily charts. Upon converting one of the charts back to a one minute intraday chart, the volume by price indicator has locked the volume bar tick count to 5 ticks, as where I'm pretty sure it was at 1 tick prior to the update. Not sure if it had anything to do with the update, but trying to give you a time line of events. It is under the chartbook titled Pound Entry, and referring specifically to chart #3. Thanks! |
[2016-10-03 17:16:10] |
Update Sierra Chart to 1467. The problem with Intraday charts switching to Historical Daily charts was resolved. Here are instructions to update: https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate Select Chart >> Chart Settings. Set the Volume at Price Multiplier to 1. Open the Study Settings window for the Volume by Price study and set the Ticks per Volume Bar to 1. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-10-03 17:17:21
