Date/Time: Fri, 10 Jan 2025 19:58:28 +0000
mirror charts in separate chartbooks?
View Count: 1048
[2016-10-03 13:38:20]
User60518 - Posts: 106
helllo,
is it possible to duplicate charts in seperate chartbooks in real time - as in if I add a study/indicator to a chart in a chartbook, this is replicated in an identical chart in another chartbook?
I want to be be able to have a single chartbook (say with a CL and a GC chart) that replicates my main charts in my independent CL & CG chartbooks.
Make sense?
Cheers
[2016-10-03 15:34:35]
Sierra Chart - Max - Posts: 5778
The feature that you are describing is called Chart Linking:
https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#LinkNumber
Chart Linking Only Works for Charts Within the Same Chartbook:
Chart Settings: Chart Linking Only Works for Charts Within the Same Chartbook
You can try to use Study Collections. You can save Chart Studies to a Study Collection and then apply them on any chart:
Study Collections
Sierra Chart Support
Date Time Of Last Edit: 2016-10-03 15:38:17
