Date/Time: Fri, 10 Jan 2025 20:00:54 +0000
Pivot Points - Variable Period Study Error
View Count: 742
[2016-10-03 04:56:49]
User948528 - Posts: 108
Need to calculate Pivot Points Variable Period only from Session Start at 18:00 to 870 minutes after at 08:30, have set accordingly per documentation, with setting of 100% of time required before plotting, but it plots throughout the entire session starting from 18:00. Screenshots of settings/chart attached.
image2016-10-03_00h44_51.png / V - Attached On 2016-10-03 04:50:29 UTC - Size: 59.12 KB - 280 views
image2016-10-03_00h43_14.png / V - Attached On 2016-10-03 04:50:36 UTC - Size: 15.08 KB - 587 views
image2016-10-03_00h51_22.png / V - Attached On 2016-10-03 04:51:36 UTC - Size: 15.33 KB - 255 views
[2016-10-03 19:16:59]
For what you want to do you must set the Session Times to only include the time period from 18:00:00 to 08:30:00. There is no other way to accomplish this.
Also do not use 100 percent for this Input:
Pivot Points: Minimum Required Time Period as %
We recommend 50 instead.
Also set these two Inputs to 1 Day:
Pivot Points: Time Period Type
