Date/Time: Fri, 10 Jan 2025 19:55:35 +0000
exporting data to TXT
View Count: 718
[2016-10-03 02:36:33] |
User774114 - Posts: 18 |
How I can make some changes in the format of the data For example, The date is exporting like 2016/09/18 and My program dont souport that I need to get 16/09/18 or 20160918 How and where can I make that ? thanks |
[2016-10-03 03:51:53] |
You will have to modify this through a spreadsheet program.
