Date/Time: Fri, 10 Jan 2025 19:59:33 +0000
Save/Load DTS Configuration does not work for version 1466
View Count: 963
[2016-10-02 16:44:54] |
tradernikki - Posts: 41 |
Exactly as the title said. The configuration doesn't change even after a different DTS setting has been loaded |
[2016-10-02 20:20:14] |
The What is New page explains this: https://www.sierrachart.com/index.php?page=doc/Whats_New.php We expect to release this feature tomorrow. However, existing saved settings will not work. You will need to resave them. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-10-02 20:21:38
[2016-10-03 13:09:41] |
I did resave them. I made new configurations using the SC 1466 and it didn't work
[2016-10-03 17:08:34] |
You need to use version 1467.
