Date/Time: Fri, 10 Jan 2025 20:22:04 +0000
super-impose large volume coloured-numbers bar?
View Count: 748
[2016-10-02 05:02:53] |
patrick - Posts: 30 |
Hi In a chartbook, I have 2 windows showing number bars. 1st window shows the unfiltered volume, 2nd window shows large volume (>299 contracts) Is it possible to super-impose the large volume coloured-numbers to the 1st window? so that I only need to look at the 1st window? Thanks. |
Attachment Deleted. 2016.10.02 .png / V - Attached On 2016-10-02 05:01:54 UTC - Size: 91.46 KB - 306 views |
[2016-10-02 07:42:48] |
No, this is not supported.
