Date/Time: Fri, 10 Jan 2025 20:19:12 +0000
Recompiling DLL File
View Count: 2034
[2016-09-30 22:16:11]
User488039 - Posts: 114
I just downloaded DeltaDivergence_v5.dll from the forum. When adding it to a chart, it says it needs to be recompiled for the current version of Sierra Chart. Can you please tell me how to recompile this indicator?
[2016-09-30 23:58:32]
You will need to find the source code file for it first. This is a CPP file.
Date Time Of Last Edit: 2016-10-01 00:04:21
[2016-10-01 00:23:49]
I have the CPP file. I'm fairly new with Sierra Chart, and I don't know where to recompile it?
Thank you
[2016-10-01 00:45:27]
Follow the instructions here:
https://www.sierrachart.com/index.php?page=doc/BuildCustomStudiesDLL.html
Also Sierra Chart has a Divergence Detector study in the latest version:
https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s382
[2016-10-01 00:51:17]
I can't seem to find the Divergence Detector you're referencing? I'm using Version 1448.
[2016-10-01 01:21:31]
You are not running the latest version. You need to update with Help >> Download Current Version.
[2016-10-01 01:40:13]
Thank you. I downloaded and installed the currecnt version of SC.
Please excuse my ignorance... I have the Divergence Detector added to a chart, but it's not showing up on the chart? Is this possible, because the market is closed?
Date Time Of Last Edit: 2016-10-01 02:09:43
[2016-10-01 02:22:24]
You need to understand how it works:
[2016-10-01 02:33:51]
Ok, I see the signals on the chart.
