Date/Time: Sun, 24 Nov 2024 05:20:24 +0000
[User Discussion] - Draw alert into trigger
View Count: 1630
[2013-07-25 17:33:38]
anju - Posts: 6
Hi is it possible to turn a draw alert into a trigger? , and how can be referenced a manual draw into an ACSIL "object" for complex triggering?.
Date Time Of Last Edit: 2013-07-25 17:39:46
[2013-07-25 17:47:18]
You need to use this function to access a user drawn drawing from ACSIL:
https://www.sierrachart.com/index.php?l=doc/doc_DLLTools.html#scGetChartDrawing
[2013-07-25 23:12:05]
anju - Posts: 6
I don't know how to make it work: I will have to create an study for a specific type of line, define an input variable with with the drawing Index, (-1 by default for apply it to last drawing), but how will I keep a reference of this line, ellipsis or whatever values in each update or "loop" for interaction, may I create a persistent variable with the draw information , or I will reference somehow the draw into a sc.Subgraph for then let the draw interact with the price and defined conditionals?
Date Time Of Last Edit: 2013-07-25 23:14:28
[2013-10-07 18:42:20]
anju - Posts: 6
any advice?
