Date/Time: Fri, 10 Jan 2025 20:20:58 +0000
How to flatten without canceling working orders for new trades?
View Count: 911
[2016-09-29 21:36:54]
phaedonk - Posts: 352
Is there a way to flatten a position via the TW and cancel only the relevant child orders (SL and target)?
I don't want Sierra to cancel other parent orders I have placed for new pending trades that have nothing to do with the current one, I then have to input then from scratch again. Many times there is simply no time for this, or mistakes are made.
If this is not supported, I strongly believe it should be.
[2016-09-30 01:04:49]
What we could do is if you have enabled Menu >> Only Orders from Chart on the Trade Window, then the canceling of orders will only apply to orders originating from that particular chart.
[2016-09-30 04:39:21]
That would mean that I would need a different chart for every set of orders I input, which is hugely impractical, a nightmare. I input all my orders from one chart.
Help me understand, is what in asking technically difficult to implement?
[2016-09-30 17:33:27]
We could add a new Trade Window option that will cause only the Attached Orders that are not in a pending state to be canceled with the Flatten and Reverse commands.
[2016-09-30 19:33:46]
Sounds great, not sure how that will work with IB orders.
Aren't they all considered working, even the child orders of parent orders that have yet to fill?
[2016-09-30 23:37:16]
This will be true in the case of when using server-side bracket orders.
Otherwise, there will not be a problem.
[2016-10-01 18:11:34]
I'm using server side orders.
Btw this also affects "hide pending attached orders from chart" (don't remember the exact phrasing), they always show.
[2016-10-02 08:28:27]
Therefore, the setting would not help in your case.
