Date/Time: Fri, 10 Jan 2025 17:36:38 +0000
SCString failing as identifier
View Count: 644
[2016-09-29 17:44:20] |
User94740 - Posts: 333 |
I have taken an extract from a custom study example and double checked according to the documentation, but after compiling I am getting an error to the following code. Code line 71: SCString Message; line 72: Message.Format("Go to", ChartNumber); Reported Error C:\SierraChart-Trading\ACS_Source>call "C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\vcvarsall.bat" TemplateTest20160927-1.cpp C:\SierraChart-Trading\ACS_Source\TemplateTest20160927-1.cpp(72): error C2065: 'Message': undeclared identifier C:\SierraChart-Trading\ACS_Source\TemplateTest20160927-1.cpp(72): error C2228: left of '.Format' must have class/struct/union C:\SierraChart-Trading\ACS_Source\TemplateTest20160927-1.cpp(72): note: type is 'unknown-type' C:\SierraChart-Trading\ACS_Source\TemplateTest20160927-1.cpp(74): error C2065: 'Message': undeclared identifier Date Time Of Last Edit: 2016-09-29 17:45:14
[2016-09-29 18:20:31] |
For the proper format for a source code file, refer to step 17 here: http://www.sierrachart.com/index.php?page=doc/AdvancedCustomStudyInterfaceAndLanguage.php#StepByStepInstructions Also this line is wrong: Message.Format("Go to", ChartNumber); It should be: Message.Format("Go to %d", ChartNumber); Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
