Date/Time: Fri, 10 Jan 2025 17:21:55 +0000
Version 1455
View Count: 644
[2016-09-29 16:03:20] |
Crtfyd - Posts: 281 |
Updated to version 1455 I've noticed that when I put an "arrow" or "Line tool" on my chart it is now under my Study "arrows, stars, etc. I looked to see if a "Keep on Top" was added or checked somewhere in this version, but can't find any. I've changed nothing from before the update. Is there somewhere I can change the default to having the arrows or lines I add to my chart from the tools to show "on top" of my study arrows, stars, dots, etc. like it used to? (Because I do know in the studies window the lower on the list has the higher precedence in layers on the charts, but a tool(arrow, dot, star, etc.)used to top the others) thx |
[2016-09-29 18:04:56] |
This is controlled through Chart Settings. Refer to: http://www.sierrachart.com/index.php?page=doc/Tools.html#DisplayOrder Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
