Date/Time: Fri, 10 Jan 2025 17:20:27 +0000
How do you chage the width of the Profile to fit it better to the screen?
View Count: 643
[2016-09-29 09:26:50] |
User840733 - Posts: 4 |
Hi, I'm looking for the function to set/modify the width of the profile and make it fir better the screen. Here are 2 screenshots that show first the profile width to change, and a correct width result I'm looking for. |
2016-09-23_Hologram_needing_width_correction.png / V - Attached On 2016-09-29 09:26:10 UTC - Size: 89.56 KB - 217 views 2016-09-23_Hologram_Comp._Prof._correct_width.png / V - Attached On 2016-09-29 09:26:24 UTC - Size: 94.08 KB - 206 views |
[2016-09-29 18:11:30] |
These are the relevant Volume by Price study Input settings: http://www.sierrachart.com/index.php?page=doc/VolumeByPrice.php#MaximumVolumeBarWidthType http://www.sierrachart.com/index.php?page=doc/VolumeByPrice.php#MaximumVolumeBarWidthPercentage Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
