Date/Time: Fri, 10 Jan 2025 17:57:23 +0000
How to share horizontal lines across charts with the same ticker symbol?
View Count: 733
[2016-09-29 09:16:56]
User840733 - Posts: 4
I try to find a way to share my horizontal lines across same symbol's chart.
Is it possible to to do it?
I mean : What I'm trying to do is to set horizontal lines on one single chart.
And set the function to automatically set the same lines on every other chart with the same ticker symbol (other time frames).
[2016-09-29 18:21:34]
This is supported. Refer to:
http://www.sierrachart.com/index.php?page=doc/helpdetails72.html
