Date/Time: Fri, 10 Jan 2025 17:58:02 +0000
2 Different Moving Average Values
View Count: 797
[2016-09-29 00:10:16] |
User299392 - Posts: 216 |
For the same exact singly chart, chartbook containing just one chart is producing 2 different values when opened in 2 different instances of Sierra at the same time. Will appreciate help resolving it, please since it is generating wrong alerts. Looks like something in the global settings is throwing it off with everything else the same even with simultaneous open state. |
[2016-09-29 00:25:28] |
Values, as indicated above refer to the Moving Average Values, as named in the subject line.
[2016-09-29 04:18:09] |
This is going to be because the bars in the chart are different in some way. Start with the very beginning bar and compare them. Most likely you will see that the first bar is different with its Date-Time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-09-29 15:17:50] |
Just checked and found that it is not the case. The starting times are exactly the same. In fact, there are other moving averages = which are ok - it is this just period MA. And this is a hour chart on Euro Futures. I must also say that other futures charts are all fine. It is just this one that is a problem. See image below - http://www.sierrachart.com/image.php?Image=1475162218238.png |
[2016-09-29 17:20:34] |
This is not true: And this is a hour chart on Euro Futures.
The chart bars are 240 minutes. If those are Moving Average-Exponential studies, refer to: http://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s27 If you have a further problem, close one of those charts and duplicate the other using this method: http://www.sierrachart.com/index.php?page=doc/ChartMenu.html#DuplicateChart Because there must be a difference with the Chart Settings or Study Settings even if you are not aware of that. We cannot provide further help. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-09-29 17:21:17
