Date/Time: Mon, 28 Sep 2026 03:50:23 +0000
Drawing Property: Anchor
View Count: 2184
[2013-07-25 14:02:36]
tobi - Posts: 351
Dear SC support,
I'm looking for a fast way to adjust horizontal rays to the pip.
Would you please consider adding the drawing property Anchors to the Customize Chart Drawing Menu?
[2013-07-25 18:02:13]
You can change the anchor values through Chart Drawing Properties when you right-click on the drawing.
[2013-07-25 19:42:14]
tobi - Posts: 351
I know of this possibility. Another way to get there is to double-click on the drawing.
I'm just looking for a faster way to get to the Anchor menu.
[2013-07-27 01:42:02]
Do you mean get to the Anchors tab of the Chart Drawing Properties window?
We suppose we could add a command that takes you straight to that tab.
Date Time Of Last Edit: 2013-07-27 01:43:08
[2013-07-27 06:45:54]
tobi - Posts: 351
Yes, that's exactly what I mean.
That'd be very nice if you could add this.
[2013-07-27 09:46:20]
OK we will see.
