Date/Time: Fri, 10 Jan 2025 17:29:05 +0000
chart corrupted red rectangle on bottom right hand side
View Count: 800
[2016-09-28 20:22:09]
User472677 - Posts: 356
Often one or more of the charts get a red rectangle on bottom right hand side. When this happens, the only way II have found to get data in the chart is to delete the chart and start a new chart. Normally this rectangle is green.
1. Is there an easier way to recover?
2. What causes this?
3. What does the number inside the rectangle mean?
Thx
[2016-09-28 20:40:43]
This means the chart is not scrolled to the end. To go to the end select Chart >> Goto End of Chart
There is also a shortcut key for this which is displayed by the menu command.
The Working with Charts documentation page explains the lower right indicators on the chart.
Date Time Of Last Edit: 2016-09-28 20:41:32
