Date/Time: Fri, 10 Jan 2025 17:54:46 +0000
Setting drawing LineNumber to price in ticks, then erasing if price met
View Count: 873
[2016-09-28 06:34:18] |
binaryduke - Posts: 373 |
Hi SierraChart I'm stuck on a simple problem and would appreciate a quick steer in the correct direction. I wish to draw a marker at a price level, then erase it if the price trades again. I am setting the LineNumber of the marker to the price - an int which should be the price in ticks - I'm not multiplying by sc.TickSize. The code to draw the marker works fine. Each time the routine is called, I call: sc.DeleteACSChartDrawing (0, TOOL_DELETE_CHARTDRAWING, sc.LastTradePrice); I would presume that if no drawing exists with a LineNumber of sc.LastTradePrice there's no harm done, however, the previously drawn markers do not erase. From this I presume the LineNumber is not set to what I'm expecting. I'd appreciate a steer as to what I'm missing. Many thanks Lee. |
[2016-09-28 19:16:42] |
Here is a code example: SCSFExport scsf_DeleteACSChartDrawingExample(SCStudyInterfaceRef sc) { // Set configuration variables if (sc.SetDefaults) { sc.GraphName = "Delete ACS Chart Drawing Example"; sc.StudyDescription = ""; sc.GraphRegion = 0; sc.FreeDLL = 0; sc.AutoLoop = 0; //No automatic looping return; } int& LineNumber = sc.GetPersistentInt(1); //Only do processing on the last bar if (sc.IsFullRecalculation) { //Set the previously remembered line number to 0 because on a full recalculation advanced custom study drawings are automatically deleted LineNumber = 0; return; } if(LineNumber != 0) { int Result = sc.DeleteACSChartDrawing(sc.ChartNumber,TOOL_DELETE_CHARTDRAWING, LineNumber); LineNumber = 0; } s_UseTool Tool; Tool.ChartNumber = sc.ChartNumber; //Tool.LineNumber will be automatically set. No need to set this. Tool.DrawingType = DRAWING_MARKER; Tool.BeginIndex = sc.ArraySize - 1; Tool.MarkerType = MARKER_ARROWUP; Tool.BeginValue = sc.Low[sc.ArraySize - 1]; Tool.Region = 0; Tool.Color = RGB(0, 255, 0); Tool.MarkerSize = 8; Tool.LineWidth = 4; Tool.AddMethod = UTAM_ADD_ALWAYS; sc.UseTool(Tool); // Here we make the function call to add the marker //Remember the line number so it can be deleted at the beginning of the function when set LineNumber = Tool.LineNumber; } Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
