Date/Time: Fri, 10 Jan 2025 16:27:40 +0000
accessing base data from different chart
View Count: 770
[2016-09-27 16:05:22] |
User44130 - Posts: 23 |
Have problem with this method of accessing base chart data from a different chart. Trying to get Last price array. SCInputRef StudySubgraphReference = sc.Input[0]; StudySubgraphReference.Name = "Study And Subgraph To Display"; StudySubgraphReference.SetChartStudySubgraphValues(1, 0, 3); SCFloatArray StudyData; sc.GetStudyArrayFromChartUsingID(StudySubgraphReference.GetChartStudySubgraphValues(), StudyData); It works ok for futures data during testing but for pair stock - market stat charts it cannot read base data. |
[2016-09-27 17:04:18] |
That code looks correct. The symbol of the chart has no effect on this whatsoever. There must be some other problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
