Date/Time: Fri, 10 Jan 2025 16:55:09 +0000
Index of the Array
View Count: 774
[2016-09-27 13:28:26] |
User103305 - Posts: 8 |
Hi, I wanted to ask something about the looping. I have a loop like this: for (int Index = 0; Index < 50; ++Index) { if (sc.Subgraph[3][Index] != 0) etc.... } First Index of the Array is 0 isnĀ“t it?? Why then the loop start to iterate from the last value on the chart and not from the first one?? Thx. Best regards, |
[2016-09-27 17:27:50] |
This has already been answered here: Array Looping Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
