Date/Time: Fri, 10 Jan 2025 16:09:53 +0000
Options trading - rarely updated quotes
View Count: 836
[2016-09-27 12:29:22] |
BrMa - Posts: 80 |
Dear ladies and gentlemen, I'd like to trade options on the Eurex using the CQG datafeed. Therefore I created a QuoteBoard in Sierra Chart and added the Calls and Puts on the DAX I wanna have a look at. So far this works perfectly fine. I have one issue when watching the quote board: the quotes for the options are updated quite rarely - e.g. now it's 14:21 and some of the quotes have been updated at 11:23! Is there a possiblilty to make all quotes in the QuoteBoard updating regularly? Thank you & regards, Markus |
[2016-09-27 17:30:54] |
The "Last" trade price is only going to update when there is a trade. If not, we would need to ask CQG about that. You should look at the Bid and Ask prices for the current price. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
