Date/Time: Fri, 10 Jan 2025 16:23:16 +0000
Last Entry/Exit Fill Bar Number in Spreadsheet Trading System
View Count: 699
[2016-09-27 11:06:36]
User787778 - Posts: 142
Would you please add:
1. Last entry fill bar number
2. Last exit fill bar number
- To the column "J" in the Spreadsheet System for Trading study.
Thanks in advance.
[2016-09-27 17:19:26]
These are not fields that we would add.
You can get a reference to a spreadsheet cell by using this function:
https://www.sierrachart.com/index.php?page=doc/SpreadsheetFunctions.html#GetCorrespondingMatch_Function
Or you need to use ACSIL instead and determine these programmatically. Refer to:
Advanced Custom Study Interface and Language (ACSIL)
Date Time Of Last Edit: 2016-09-27 17:20:08
