Date/Time: Fri, 10 Jan 2025 16:40:45 +0000
Missing Historical Data
View Count: 739
[2016-09-27 09:22:30]
User792637 - Posts: 4
Hi
I used to get historical data for Crude oil (CL) but it won't load anything more recent than the 20th May 2016. I have an FXCM account and so use the SC Forex Data(FXCM) feed. I notice I have he same issue now on the S&P500. Has the historical data support stopped or am I doing something wrong. I still see up-to-date data for Gold and all the FX pairs?
imageCrude Oil Chart.PNG / V - Attached On 2016-09-27 09:21:27 UTC - Size: 31.26 KB - 247 views
imageUs Oil Feed.PNG / V - Attached On 2016-09-27 09:21:48 UTC - Size: 11.64 KB - 263 views
[2016-09-27 09:48:36]
Follow the instructions here:
For futures you need to follow the instructions here to use the Sierra Chart Historical Data Service:
Sierra Chart Historical Data Service: Setup Instructions
You will also have access to the SC Forex Data as well, when using that service.
[2016-09-27 10:57:18]
Hi
I don't have the option to choose SC Data All Services. I only have SC Forex Data or SC Historical Data? So I am unable to follow your instructions?
[2016-09-27 17:23:19]
This means you are running an older version of Sierra Chart. If you do not have a dependency on Old Spreadsheets, then update:
https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate
Otherwise, install another copy of Sierra Chart in a different folder and set it to use SC Data - All Services. Refer to:
Using Multiple Data and Trading Services at the Same Time
You can use this other copy of Sierra Chart for futures charts.
Date Time Of Last Edit: 2016-09-27 17:24:30
