Date/Time: Fri, 10 Jan 2025 16:28:13 +0000
Global settings >> General Trade settings
View Count: 1042
[2016-09-27 05:46:56] |
User553714 - Posts: 184 |
Hi, I have changed the number of days to be saved under Global settings >> General Trade settings >> Number of days to save in the trade activity log, but it doesn't seem to save my preferences for low numbers of days; I would like to be able to only save 1-3 days of history only as I am using cell locks in my trading spreadsheet to put in trading halts, having a long history stuffs with this; is there a reason why I can't save my preferences for only 1-3 days of history in these settings? Any number under 5-days for non-simulated and non-sim fills doesn't get saved and it seems to revert back to defaults of 5 and 186 resp. Simulated can be set to 0 and gets saved ok. |
[2016-09-27 07:22:32] |
The minimum setting for non-simulated order fills is 5 days. You can control this for each individual chart and set a starting date-time: Chart Settings: Order Fills Start Date-Time (Chart >> Chart Settings >> Trading menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
