Date/Time: Fri, 10 Jan 2025 16:33:15 +0000
TPO profile open
View Count: 1659
[2016-09-26 20:40:23]
User57210 - Posts: 121
Hello, this issue has persisted in SC for as long as I've used it, but I'm just now getting around to pointing it out to you guys. Occasionally, the opening print is not highlighted in a day's profile. This doesn't occur when the tick increment is set to 1, but many TPO guys vary our tick sizes based on the volatility of the market being charted. Today's RTH only profile for ES futures set to a 4 tick setting does not highlight the opening print for me.
Hoping you guys have an easy fix for this.
Cheers.
[2016-09-26 20:50:27]
I am very sorry. The example is CL futures today with a 4 tick setting. 9:00 to 14:29:59 timeframe. EST.
Date Time Of Last Edit: 2016-09-26 20:50:45
[2016-09-27 00:29:26]
Are you sure you set the color for the Open Marker Color correctly. Refer to:
https://www.sierrachart.com/index.php?page=doc/TPOVolProfileCharts.html#ColorAndWidthSettings
We see it with this configuration for 9-26:
http://www.sierrachart.com/image.php?Image=147493611031.png
Date Time Of Last Edit: 2016-09-27 00:29:52
[2016-09-27 22:32:00]
I have four different TPO charts up, and each of them do this from time to time. See my 9/26 and its lack of highlighted opening print versus the other days that look fine. http://screencast.com/t/WHd3wg2mW
[2016-09-27 23:23:03]
When posting an image of a chart only use the method documented here:
Attach a Chartbook containing a single chart showing this problem. Here are instructions:
https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile
