Date/Time: Fri, 10 Jan 2025 16:21:02 +0000
How to paint price candles with net ask-bid calc.
View Count: 2007
[2016-09-26 15:04:03] |
User341584 - Posts: 44 |
How would one paint price candles with the net ask-bid of that candle? Any insight would be appreciated Thanks M |
[2016-09-26 17:03:47] |
If you are referring to Bid Volume and Ask Volume, then use this study: http://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s291 (Ask/Bid Volume Difference Bars) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-09-26 17:04:20
[2016-09-26 17:08:29] |
Kind of. I would like these difference colors to be painted on the candles or bars of chart region 1... Thank you M |
[2016-09-26 17:17:27] |
For this, use the Color Bar Based on Alert Condition study: http://www.sierrachart.com/index.php?page=doc/ColorBarBasedOnAlertCondition.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
