Date/Time: Fri, 10 Jan 2025 16:19:52 +0000
how to display the dom of a product in teh cgart or dom of another product.
View Count: 602
[2016-09-26 14:50:49] |
sierra28 - Posts: 120 |
is it possible to display two differents dom in the same chart or dom? thanks Date Time Of Last Edit: 2016-09-26 14:51:04
[2016-09-26 16:47:41] |
This can be done with the Trade and Current Quote Symbol setting: http://www.sierrachart.com/index.php?page=doc/ChartSettings.html#TradeAndCurrentQuoteSymbol However, this other symbol must be available on the particular data feed being used. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
