Date/Time: Fri, 10 Jan 2025 16:10:22 +0000
using your feed with ameritrade
View Count: 682
[2016-09-26 12:41:39] |
User170575 - Posts: 221 |
Good Morning, I signed up for your datafeed and I want to use Ameritrade for my execution. So in the Data/Trade Service Setting I have SC Data- All Services selected. Where do I differentiate the broker? Many thanks, CJ |
[2016-09-26 16:49:55] |
You need to set the Service in Sierra Chart to TD Ameritrade. Follow the instructions here: http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#IntegrationWithTradingServices Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
