Date/Time: Fri, 10 Jan 2025 16:35:25 +0000
Color Bar Base On Alert Condition
View Count: 1353
[2016-09-26 12:33:55] |
infpz - Posts: 826 |
Is it possible to be alerted if 90 of the last XXXX bars have a volume under 3000 contracts? In other words, is there some function that can search for such a condition without ASCIL? |
[2016-09-26 16:55:24] |
For this you will want to use the Spreadsheet System/Alert study: http://www.sierrachart.com/index.php?page=doc/SystemsAlerts.php You would need to use a formula column containing this formula: ID0.SG5@3 > 3000. And then use another formula column to SUM the previous 90 cells of that other column and see if the result is 90 or greater. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-09-26 16:55:52
