Date/Time: Fri, 10 Jan 2025 16:34:51 +0000
Control Bar Issues
View Count: 731
[2016-09-26 11:55:02] |
User962398 - Posts: 4 |
My Control bar is just one big grey bar with no options. When I right click it gives me the option to customize the control bar and it shows the correct settings for control bar 1 and I apply and it doesn't do anything it stays as one big grey bar.
Screenshot of Toolbar.PNG / V - Attached On 2016-09-26 11:54:36 UTC - Size: 133.51 KB - 228 views |
[2016-09-26 17:11:59] |
You need to reduce the font size. Follow the instructions here: http://www.sierrachart.com/index.php?page=doc/ControlBar.php#ControlBarButtonsTooLarge Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-09-26 19:07:27] |
That fixed it. Thanks!!
