Date/Time: Fri, 10 Jan 2025 16:51:04 +0000
no connection to datafeed
View Count: 724
[2016-09-26 06:38:49]
nicktrader - Posts: 725
Since Saturday I do not get any connection.
Reading Internal Order ID file. | 2016-09-26 08:34:03
Reading Trade Orders file. | 2016-09-26 08:34:03
Reading Trade Positions file. | 2016-09-26 08:34:03
Software version: 1463 | 2016-09-26 08:34:03
Uses New Spreadsheets | 2016-09-26 08:34:03
Usage end date: 2017-01-04 | 2016-09-26 08:34:03
Enabled for: Advanced Features. | 2016-09-26 08:34:03
Enabled for: Sierra Chart Historical Data Service. | 2016-09-26 08:34:03
Allow Support for Sierra Chart Data Feeds is enabled. | 2016-09-26 08:34:03
Current selected Data/Trading service: CQG FIX Trading | 2016-09-26 08:34:03
Chart Update Interval: 500 | 2016-09-26 08:34:03
Time Zone: +02:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2016-09-26 08:34:03
2016-09-26 08:34:06 Local computer time | 2016-09-26 08:34:03
2016-09-26 06:34:06 Local computer time in UTC | 2016-09-26 08:34:03
2016-09-26 08:34:06 Local computer time in SC Time Zone | 2016-09-26 08:34:03
2016-09-26 06:34:06 Server time in UTC | 2016-09-26 08:34:03
Local computer UTC time and Server UTC time difference: 0 seconds. | 2016-09-26 08:34:03
Program path: C:\SierraChart\ | 2016-09-26 08:34:03
Data Files path: C:\SierraChart\Data\ | 2016-09-26 08:34:03
OS Version Number: 6.2 | 2016-09-26 08:34:03
Locale Setting: C | 2016-09-26 08:34:03
Created the DTC Protocol server. | 2016-09-26 08:34:03
DTC Protocol Server listening on port 11099. | 2016-09-26 08:34:03
Created the DTC Protocol historical data server. | 2016-09-26 08:34:03
HD Server Manager | Listening on port 11098 | 2016-09-26 08:34:03
Checking for new symbol settings for cqg | 2016-09-26 08:34:03
HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-09-26 08:34:03
HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2016-09-26 08:34:03
HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2016-09-26 08:34:03
HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2016-09-26 08:34:03
Symbol settings are up-to-date for cqg | 2016-09-26 08:34:03
CQG FIX: Connecting to demo.cqgtrader.com. Port: 6925. | 2016-09-26 08:35:59
socket (0) | Resolved address demo.cqgtrader.com to IP 208.48.16.202. | 2016-09-26 08:35:59
socket (27) | Connected. | 2016-09-26 08:35:59
socket (27) | Starting TLS 1.2 connection. | 2016-09-26 08:35:59
socket (27) | SSL connection established. | 2016-09-26 08:35:59
CQG FIX: Sending the Logon message. | 2016-09-26 08:35:59
CQG FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2016-09-26 08:36:00
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-09-26 08:36:00
socket (27) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-26 08:36:00
socket (27) | SSL has been shut down. | 2016-09-26 08:36:00
socket (27) | SSL object has been freed. SSL state is now disconnected. | 2016-09-26 08:36:00
socket (27) | Shutdown and closed. | 2016-09-26 08:36:00
CQG FIX: Disconnected. | 2016-09-26 08:36:00
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-09-26 08:36:00
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-09-26 08:36:00
CQG FIX Trading | Disconnected. | 2016-09-26 08:36:00
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-09-26 08:36:00
CQG FIX: Connecting to demo.cqgtrader.com. Port: 6925. | 2016-09-26 08:36:03
socket (0) | Resolved address demo.cqgtrader.com to IP 208.48.16.202. | 2016-09-26 08:36:03
socket (28) | Connected. | 2016-09-26 08:36:03
socket (28) | Starting TLS 1.2 connection. | 2016-09-26 08:36:03
socket (28) | SSL connection established. | 2016-09-26 08:36:03
CQG FIX: Sending the Logon message. | 2016-09-26 08:36:03
CQG FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2016-09-26 08:36:03
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-09-26 08:36:03
socket (28) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-26 08:36:03
socket (28) | SSL has been shut down. | 2016-09-26 08:36:03
socket (28) | SSL object has been freed. SSL state is now disconnected. | 2016-09-26 08:36:03
socket (28) | Shutdown and closed. | 2016-09-26 08:36:03
CQG FIX: Disconnected. | 2016-09-26 08:36:03
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-09-26 08:36:03
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-09-26 08:36:03
CQG FIX Trading | Disconnected. | 2016-09-26 08:36:03
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-09-26 08:36:03
CQG FIX: Connecting to demo.cqgtrader.com. Port: 6925. | 2016-09-26 08:36:06
socket (0) | Resolved address demo.cqgtrader.com to IP 208.48.16.202. | 2016-09-26 08:36:06
socket (30) | Connected. | 2016-09-26 08:36:07
socket (30) | Starting TLS 1.2 connection. | 2016-09-26 08:36:07
socket (30) | SSL connection established. | 2016-09-26 08:36:07
CQG FIX: Sending the Logon message. | 2016-09-26 08:36:07
CQG FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2016-09-26 08:36:07
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-09-26 08:36:07
socket (30) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-26 08:36:07
socket (30) | SSL has been shut down. | 2016-09-26 08:36:07
socket (30) | SSL object has been freed. SSL state is now disconnected. | 2016-09-26 08:36:07
socket (30) | Shutdown and closed. | 2016-09-26 08:36:07
CQG FIX: Disconnected. | 2016-09-26 08:36:07
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-09-26 08:36:07
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-09-26 08:36:07
CQG FIX Trading | Disconnected. | 2016-09-26 08:36:07
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-09-26 08:36:07
CQG FIX: Connecting to demo.cqgtrader.com. Port: 6925. | 2016-09-26 08:36:10
socket (0) | Resolved address demo.cqgtrader.com to IP 208.48.16.202. | 2016-09-26 08:36:10
socket (31) | Connected. | 2016-09-26 08:36:10
socket (31) | Starting TLS 1.2 connection. | 2016-09-26 08:36:10
socket (31) | SSL connection established. | 2016-09-26 08:36:11
CQG FIX: Sending the Logon message. | 2016-09-26 08:36:11
CQG FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2016-09-26 08:36:11
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-09-26 08:36:11
socket (31) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-26 08:36:11
socket (31) | SSL has been shut down. | 2016-09-26 08:36:11
socket (31) | SSL object has been freed. SSL state is now disconnected. | 2016-09-26 08:36:11
socket (31) | Shutdown and closed. | 2016-09-26 08:36:11
CQG FIX: Disconnected. | 2016-09-26 08:36:11
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-09-26 08:36:11
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-09-26 08:36:11
CQG FIX Trading | Disconnected. | 2016-09-26 08:36:11
Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-09-26 08:36:11
Date Time Of Last Edit: 2016-09-26 06:51:38
[2016-09-26 06:51:13]
Most likely because Sierra Chart is connecting to the CQG demo server:
CQG FIX: Connecting to demo.cqgtrader.com. Port: 6925. | 2016-09-26 08:34:33
Select Global Settings >> Data/Trade Service Settings.
Set the "Server" to Live.
Date Time Of Last Edit: 2016-09-26 06:52:11
[2016-09-26 08:03:34]
Same old story. I made an update and after starting it changed by itself to DEMO.
I do not know why.
Reading Internal Order ID file. | 2016-09-26 09:57:29
Reading Trade Orders file. | 2016-09-26 09:57:29
Reading Trade Positions file. | 2016-09-26 09:57:29
Software version: 1460 | 2016-09-26 09:57:29
Uses New Spreadsheets | 2016-09-26 09:57:29
Usage end date: 2017-01-04 | 2016-09-26 09:57:29
Enabled for: Advanced Features. | 2016-09-26 09:57:29
Enabled for: Sierra Chart Historical Data Service. | 2016-09-26 09:57:29
Allow Support for Sierra Chart Data Feeds is enabled. | 2016-09-26 09:57:29
Current selected Data/Trading service: CQG FIX Trading | 2016-09-26 09:57:29
Chart Update Interval: 500 | 2016-09-26 09:57:29
Time Zone: +02:00:00 (CET+01CEST+01,M3.5.0/02:00,M10.5.0/03:00) | 2016-09-26 09:57:29
2016-09-26 09:57:32 Local computer time | 2016-09-26 09:57:29
2016-09-26 07:57:32 Local computer time in UTC | 2016-09-26 09:57:29
2016-09-26 09:57:32 Local computer time in SC Time Zone | 2016-09-26 09:57:29
2016-09-26 07:57:31 Server time in UTC | 2016-09-26 09:57:29
Local computer UTC time and Server UTC time difference: 0 seconds. | 2016-09-26 09:57:29
Program path: C:\SierraChart\ | 2016-09-26 09:57:29
Data Files path: C:\SierraChart\Data\ | 2016-09-26 09:57:29
OS Version Number: 6.2 | 2016-09-26 09:57:29
Locale Setting: C | 2016-09-26 09:57:29
Created the DTC Protocol server. | 2016-09-26 09:57:29
DTC Protocol Server listening on port 11099. | 2016-09-26 09:57:29
Created the DTC Protocol historical data server. | 2016-09-26 09:57:29
HD Server Manager | Listening on port 11098 | 2016-09-26 09:57:29
Checking for new symbol settings for cqg | 2016-09-26 09:57:29
HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236. | 2016-09-26 09:57:29
HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2016-09-26 09:57:29
HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2016-09-26 09:57:29
HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2016-09-26 09:57:29
Requesting symbol settings for cqg. Overwrite = on. | 2016-09-26 09:57:29
Symbol settings received. | 2016-09-26 09:57:33
Processed 852 symbol settings. | 2016-09-26 09:57:33
CQG FIX: Connecting to demo.cqgtrader.com. Port: 6925. | 2016-09-26 10:00:51
socket (0) | Resolved address demo.cqgtrader.com to IP 208.48.16.202. | 2016-09-26 10:00:51
socket (58) | Connected. | 2016-09-26 10:00:51
socket (58) | Starting TLS 1.2 connection. | 2016-09-26 10:00:51
socket (58) | SSL connection established. | 2016-09-26 10:00:52
CQG FIX: Sending the Logon message. | 2016-09-26 10:00:52
CQG FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2016-09-26 10:00:52
CQG FIX: Sending a Logout message. Text = Received Logout message. | 2016-09-26 10:00:52
socket (58) | SSL shutdown indicates not able to send 'close notify'. | 2016-09-26 10:00:52
socket (58) | SSL has been shut down. | 2016-09-26 10:00:52
socket (58) | SSL object has been freed. SSL state is now disconnected. | 2016-09-26 10:00:52
socket (58) | Shutdown and closed. | 2016-09-26 10:00:52
CQG FIX: Disconnected. | 2016-09-26 10:00:52
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-09-26 10:00:52
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-09-26 10:00:52
CQG FIX Trading | Disconnected. | 2016-09-26 10:00:52
Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-09-26 10:00:52
Date Time Of Last Edit: 2016-09-26 08:39:49
[2016-09-26 08:39:19]
You need to set the Server back to "Live":
Set the "Server" setting to Live.
Press OK.
Date Time Of Last Edit: 2016-09-26 08:40:27
