Date/Time: Fri, 10 Jan 2025 16:46:35 +0000
Can't connect
View Count: 656
[2016-09-25 11:18:52] |
User85924 - Posts: 3 |
Dear support Team, Can you please check why I can't connect? I extended my license today but sierra is in mode of connecting or waiting for reconect. Thank you Kind Regards Sona Date Time Of Last Edit: 2016-09-25 11:19:25
[2016-09-25 20:51:29] |
Provide a copy of the Message Log by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
